According to the FCC ( Federal Candy Company
), channel 16 is reserved for Calling and Distress only. The proper usage, as defined, is that a user may call another boat, then change to another channel ( in this case, likely one assigned for recreational boat non-critical communications, such as 68 ). Again, according to da rules, "Thou shall not chat" on 16.
There is MUCH confusion about using channel 9 as a "boater calling frequency". It certainly is available for such use, but if you have one radio, and obey the rule to monitor 16, then you ( and everyone else ) will never hear a call on ch 9. The USCG has, from time to time, attempted to get boaters to switch to 9 and the FCC has not backed up this idea. Personally, my license is issued by the FCC, so I go with their rules...
As far as, "How many of you use your VHF regularly. When you do is there a specific protocol to use."
The VHF gets turned on after I raise the antennas, but before I turn on the GPS ( and before I start engines or untie from the dock ). It remains on, on Ch 16, unless I am in active communications on another channel. Protocol? Yes, sort of. You should use the proper channel for the type of communication you are doing. Wanna talk about that 7 lb trout you caught? Use Ch 68 ( or other Ch with the same usage assignment ).
And the most important protocol there is: NEVER INTERRUPT AN EMERGENCY COMMUNICATION. Listen ( esp on 16 ) before you press the key. Make sure that the channel really is not in use. Remember that emergency response might be able to hear both you and the boat that is on fire, even though you may not be able to hear the boat. Odds are that your call to "Bumboat" will prevent SAR from getting the location of the boat in distress.
-edit-
Robbins29, tks for the link to Part 80...
And here is the
link to the channel assignment/usage list
