Slip Dimensions - Minimum recommend width?
ChefJunk
I am in the process of selecting a marina on Lake Erie for 2008. My preferred marina has only one slip left on the dock I want. It is 12'8" wide. It is a single slip with elevated cement pier to port and a floating finger dock to starboard. I am 28', 30' over all and my beam is 11'1". They said it would be tight but do-able. Since this is my first boat on my own, I am not willing to go that tight, at least for my first season. The boat is in too good of condition and I am not that confident in my abilities on a larger (for me) vessel.
This search does raise the following questions for me...
1. What is the minimum width for a 30' boat in a single slip?
2. What is the minimum width for a 30' boat in a double slip, assume the second vessel is the same width.
Thanks for your help!
it has little to do with your abilities to dock the boat but it really depends on how exposed the slip is. if it's in a very calm marina, well protected from wakes and wind, you can get away with as little as a foot on each side or less, especially on floating docks. If you have fixed docks and you need to use longer lines because of tides, then 18" to 24" on each side is probably better.
if you slip is exposed to wind, wakes or to a long fetch, at least 2' on each side. or else the stretch in the lines will not let you keep the boat off the piling or pier.
dont' count on fenders with pilings, they often slip around... or you need to use fender boards and that's 3 times the work when you want to leave. Even on a floating dock, fenders will eventually mark the hulls, so keeping the boat off with lines is better.
Minimum would be simply wide enough for you to get the boat in there. Ideally having room on each side to allow space for your fenders seems about right. 12' 8" I would take if that is all they have.
I thnk a tight slip is better than a double slip. Less chance of having your neighbor 'bump' you when he docks (or visa-versa). I'm not sure of the model of you boat, but chances are that it's not 11'1 at dock level.
It sounds like your slip has about the same clearance mine has. I back in and tie the bow off so it is centered in the dock. I cross tie the stern so that it is six in. from the pier. I spring it fore and aft on the pier side from a midship cleat.If you tie this way in normal conditions,and have tied to pilings and pier keeping your knots at deck level,you should not rub when the lake goes up or down a few feet. It works for me on western lake Erie where we get a swing of several feet.
We have floating U dock slips, last year we were 12.5 beam in a 14 wide, this year 14.3 in a 16...never had any problems, actually preferred it for washing, filling water tanks, etc... We are in a very protected marina however... No tide to worry about either...
This is last years 340 in a 14ft wide.. Note the PVC pipe I put on the uprights, this was because they were too low (below the rub rail)... Backing in was a breeze...
another factor is number of engines. with 2, you'll be much more maneuverable and able to get into tighter places more easily thank with 1. so if you'll have 2 engines, you may not need as much extra space as you think. however, as pascal points out, protection from wind and current will play a really big factor.
A year ago I'd have said "a floating pier on one side? No problem!". However, Pascal is right (again). We keep our 30x10 boat in a 42x16' non-floating slip, and I'm really happy with it. Our normal tides are just a few feet. But when the winter winds blow for longer than a day here off the Chesapeake from the N or NW, water gets pushed out of the Bay and we can drop an extra 3-4 feet. With the amount of room I have, my lines are long enough to compensate. However, I've thought about leaving our slip and going to a floating pier marina. This past year we were at such a place with some very strange 3-footers (swells) coming in. We had tied up tight to the finger pier with fenders. I'm glad we hadn't left the boat when this started to happen. The fenders (very much over-sized for our boat) were pushed to the max to protect our hull. Many of the slip-holders around us were banging into the finger piers (I did call the office and got help out to try and protect what we all could).
Bottom line: floating piers aren't the end-all, be-all. It's better to have some room all the way around (bow too, in case your neighbor can't quite get in the slip and ends up sliding down your pilings....or your anchor...or your bow!)
Absolutely agree with this!
My boat with 10' 6" beam is currently in a 12' slip. (The slip may be 12' 2" or 3".) In most conditions all is well. However, we recently had a 3 day North wind and it blew a lot of water out of the bay. The short dock lines that you use a small slip just do not have sufficient play to handle large tidal changes. I actually had to cut one of the mid deck lines because they were so tight on both sides that I could not untie.
If you are on a floating dock, no problem. If you are on a lake with no water level change again no problem. I have no idea of how lake Erie performs.
As soon as a wider slip is available I am moving.
G
Now that I've been to several marinas and various floating/non-floating slip arrangements, I feel like the tighter the slip the better. I moved down two slips in our marina to one that is a bit more narrow and find it much easier to cast off, tie up, etc. Especially when the wind is howling. I have a 13'6" beam and once had a 15 knot head wind blowing into a 14' slip up in Tarpon springs. The fact that the slip was narrow kept me off the neighbors and it was easier to lean on the posts as I backed in.
At first I thought I wanted a nice wide target to hit as I learned docking. Actually not such a good idea. I have to agree with Pascal on his comments.
Pretty much what Pascal said. Tighter is not a bad thing, up to the point that your fenders do not have enough room to move. Once you have that much room, adding more does not really help.
Also with floating piers (which is nearly exclusively what you find in our area due to daily tides that move 8-13 feet of water, you need to actually go and do the math on the waterline beam width. It is very common to find that your 11'1 beam at waterline is much less. We once put an 11foot beam boat in a 11 foot beam slip and it ended up having tons of room to spare. Boats look like this: / and the pointy end is most near the waterline and dock.
bp
If you like the location go for it. You will learn to back in. Remember SLOOOW is good and your friend.
I park a 12ft Chris in a 13ft slip all the time. Just takes a little practice, and don't be afraid to make a "go around" if you miss, everyone does sooner or later.
a situatin going with a slip to big,
when we were in teh keys i had to rent the 60 x 20 slip. i thought it was a real paing because i had to drive to each piling to pick up the bow lines.
i personally prefer a slip just big enough to allow necessary movement and fender room. much bigger is just a pain.
i also look for a slip with a piling to pivot off of if the winds are blowing me in to my neighbors slip. i alwasy say that pilings are your friends if you use them right.
Amen. My 2465 (8'6" beam) Regal was in a 35x14 slip. It was so painful I went to drystack the next year until the slip that I wanted (small private dock against the sea wall bult by PO) became available. Worked great! I am now on floaters right across from the launch ramp. I am as far away from the river as you can get w/o going on the hard. I love it. Wouldn't change them for the world.
Joe,
in a wider slip, all you need is a boat hook to get the lines, if real wide then a telescopic boat hook works great.
A wide slip gives you more option to position the boat, you cna leave 6' on one side, and just 2 on the side you board from. Not having to worry about fenders saves a lot of time too.
i'm at the end of a long pier and walk by about 60 boats, of all sizes. I can tell you from those in tight slips that fenders are just bandaids, nothing more. Those in wide slips on the other hand can rig their lines to position the boat exactly where they need it.
now, it's not a deal breaker, if you all you have is a narrow slip then make it work... but it's not as convenient. And again, a lot depends on the slip configuration and exposure. The original post mentions concrete pier on one side, how is that protected? are they wood piling against the concrete?
many many factors
Pascal -- acutally in my case i could not reach the far piling with my boat hook. with out doing the a squared + b squared = c squared math i can tell you that to tie to the finger pier there was no way to reach that out piling with a boat hook. i actually had to break out hte 35' lines to make it reach my bow cleat.
i do agree about having more choices in bigger slips. i am going to the next size up (long story but it is cheaper)and now will have the choice to bow in, which will be a nice change. alos i will be able to wash down almost the entire boat from the dock and not have to hang over the bow flare to rinse down that area.
I had a wide slip which worked great as I learned to dock. But there came a point where I'd back in fine but being single handed, by the time I jumped off the boat, I'd be blown into my neighbor (with fenders) and have to struggle to get the bow back. I did figure out that dropping a long bow line on the dock BEFORE I jumped off the boat was a good idea :)
If it has pilings, go for it...you just have to line the rub rail against the piling and pivot off them to squeeze in.
Joe,
This sounds like our trip to A&B Marina in the Key West Bight. Exact same circumstance. I could almost turn the boat around in their last available slip.
Lake Erie conditions are very similar to our conditions on Lake Michigan. We have a 13 foot beam and have no trouble getting into protected slips that have just a few inches to spare on each side. 13 1/2 to 14 feet, no problem with a 4 way tie and 2 spring lines. That's for when we are traveling. My home slips are 55' by 17' and I had them built when our boat at the time had a beam of 12 1/2 feet. I prefer the 17 feet width because it allows a friend's 45 foot Viking the room he needs. I like the width for me, because we live on an inland lake with prevailing SW winds and our slip runs north and south. There are many days when the wind is blowing 15-25 MPH and the width of the slip allows me to come in hot, crab into the wind and then pull the bow down wind into the slip before reversing power. In effect it's like making a crosswind landing in an airplane. If the slip was too narrow we would have trouble going out on windy days. So, it all depends on local conditions. BTW, the more challenging the slip, the better your seamanship skills will be with experience. I used to fret over docking, but can get into just about anything today after 40 years of practice.
The best crew member i have on the boat is a telescopic hook... 15' or so fully extended! it will pick up anything, it doesnt complain doesn't use up a berth :-)
