Slip Dimensions - Minimum recommend width?
Thanks for everyones advice and comments. As soon as some of this damn ice and snow melts I am going to go take a look at that specific dock and get a second look to better make a decision.
The cement & filled pier to port angles inward toward the dock, after the slip adding one more dimension to the equation. The dock is $1175 instead of $1750 and I can still park a gas grill and picnic table on the pad in front of the slip. It overlooks the bay, coal docks, and Cedar Point (amusement park).
I will let you know when we get some relief from this weather and I can go check it out again.
If you go to http://www.dockofthebaymarina.com and look at the picture, it is in the very right hand corner of the picture. Tha Marina looks North onto Lake Erie.
$1175? Are you serious? Is that the seasonal rate? Holy Moly, wish we were so lucky, if so...
I just cut a check this week for the 16x42 for $2900, may 1 thru oct 15, but it does include water, pumpout and 3x15 amp electric...
This is a single 30 amp, city water, basic cable, and is april 15 through nov. 1, more likely may 1 - oct. 31. Yeah, now you see why I want to try to fit in there. My brother from DC plays the air violin every time I talk about dockage prices here.
Looking at the pic, the most difficult docking will be on a day with an east wind. You will be blown against the long dock as you back out of the slip or into the wall coming into the slip. As you know, we get east winds when the weather is poor so maybe that's not such a problem. SW winds will actually help you when pulling into this slip.
skeet -- that is where i had the issue, well almost, it was in conch harbor marina key west.
