Street Gas Vrs Marina Gas
Gate stations here in Northeast Florida have NonE gas. It's about 15% to 20% higher price but worth it. I set the timing on my motor back to 19* from 21* when I was using premium E10 gas and I have MORE power, smoother running and get slightly better mileage. I also use it in all my yard gear and, occasionally in my car. My work/tow car is a '98 Grand Marquis with 192K on it and still gets 21 MPG around town. But when I fill up with NonE I get 23 MPG and in 5 miles I can feel the idle smoothing out. So yes. Put to bed. Ethanol in gas IS BAD, BAD, BAD !!!!!!
Originally posted by Padraig
Not doubting anyone but wonder why some have problems with ethanol gas and others don't? I have to wonder if the water is getting in before it is pumped into the boat. For those who have had problems...was it marina gas or street?
When I used to use ethanol infested gasoline I had problems with both marina and "street" gas. It attracts too much moisture as tanks heat and cool each day.
I know I'm one of the few but I kind of like ethanol for its cleaning properties. Once you get through the initial "clean up" phase, it should be problem free. It forces you to come up with a better filtration system in the process and if you have an older boat, upgrade fuel lines. I watch guys in my marina change one hose at a time and yeah ethanol will be a nightmare if you take that approach. Upgrade everything, get through the initial batch of filters and the result will be s spotlessly clean fuel system to start.
I use Startron regularly during the season and winterized with the same.
I don't know of a marina near me that offers corn-free fuel. I have used fuel from my marina and fuel from Wawa in the spring from cans to intially fill the tank and find no difference in performance. The one time I had a problem was when I accidentally left the filler cap off and it rained. I fought performance issues for some time after that before I finally siphoned all of the fuel out. No problems since.
"so why doesn't the marina sell off road gas?" -- D. Andrews
Where I used to dock, the reason was that the marina owner skimmed fuel into his Cadillac for road use... ;)
The "old" days marinas would sell premix for outboard engines.
