Tool Set
mandm1200
I would like to get a tool set to keep on the boat. I'm getting tired of hauling my tools back and forth. Although Sears has sales decent sales, their kits are made up of both SAE and metric. I don't need metric and I see it as a waste. Anyone have a good idea of what to buy and where. I am thinking a set of combination wrenches (1/4" to 7/8"), socket set (1/4", 3/8", and ВЅ") with a limited number of sockets. I can add a screwdriver set to it and well as some pliers. I'd rather stay away from really cheap tools. The tool set would be basic. If I need to do something involved, I would bring additional tools like a breaker bar and torque wrench as needed.
Check out garage sales, the paper, pawn shops and craigs list. Sadly there are lots people selling their tools right now.
Remember that about 80% of the tools on a boat that need replacement are due to the original one going overboard, not breaking. Inexpensive tools are usually in order, Harbor Freight ( as well as garage salwe, as stated above ) are also a good plan.
I've been pretty lucky with tools on the boat. In 11 years only a screwdriver and a couple of rubber sanding blocks got deep-sixed.
I ended up getting a heavy plastic tool box, packing everything in and hauling it between the workshop and the boat. Over the years the tool collection grows. Buy the good stuff.
For a basic tool box for boats: the socket sets, packing nut wrench for inboards, pliers (including long nose and needle nose), a variety of screw drivers, vice-grips, good wire strippers, lug crimper, diagonals, tape measure, hack saw, crescent wrenches, flat wrenches, drill and bits, electrical knife, multi-meter, bastard file, and need I say it..? duck tape, nylon string and baling wire.
On a boat, one of these things is worth it's weight in gold.
As mentioned, Harbor Freight. They are on the internet and have local outlets in many major communities. The prices are very low, reflecting the source: China. Quality is fine. I cracked a Sears sparkplug socket, once, and had to use one from Harbor Freight to finsh the job. I still have many of the rosewood handled screwdrivers which I bought as a set about 30 years ago when their name was Harbor Freight and Salvage. Price for a set of 20 assorted: $2.99.
I get nothing from this recommendation and I am conflicted buying so much foreign goods but that's the current world economy. Get used to it.
I would recommend to start with a good basic set of tools.
Then purchase a medium size tool box.
Purchase specialty tools as you need them and in short time the box will be full.
Over time I have one set of tools at the house and the other in the boat.
You will carry back and forth the really expensive tools like power saws and battery drill motors as needed.
Get another box for spare parts.
Aboutime
Don't discount the need for metric tools. Even if the majority of your fasteners are SAE, some replacement parts may come with metric fasteners...A basic metric socket and wrench set should be onboard.
Better to have it and not need it, than to need it and not have it!
The onboard tool set is always a double edge sword. On the one hand, you want to be working with good tools that are reliable and you have confidence in.
On the other hand, onboard tool sets are subjected to a harsh marine environment and there is always the overboard factor. Also, your onboard toolset is not something you really want to have to use, but you want it there when needed.
I second the pawn shop comment above. Some great deal can be had out there if you are willing to look.
Oh, and rest assured that when you are trying to make a repair on the water, your tool set will have every tool excpet one - the one you need at that moment.
Did anyone mention Harbor Freight? I had a full set of their tools for my boat. Inexpensive tools are great for the boat, no worries if/when they go splash...
Harbor Freight was a good choice for me. I have a need for metric as well as standard and I saved a ton of money and got some pretty decent tools. Including the S tool set for them hard to get at nuts and bolts.
Quality wrenches and sockets are generally stronger and when it counts such as when you have a rusted bolt etc. they will save your knuckles or make the job easier.
There is a relatively new ratchet at sears that is the only one worth having these days. It has a hinge near the head, a bent handle and a longer than usual handle for a 3/8" drive set.
Whatever you buy spray everything with corrosion spray.
I have a decent set of tools in a tool box down in the engine room but I also keep one of those cheap fold-up kits you can get for $29 for day to day use that I keep in the cabin. When the cheap crap gets lost/broken/rusty or borrowed and not returned I simple by a new kit and toss the old.
For bigger jobs I break out the heavy tool box as needed.
I have a relatively complex older boat, so won't get into all the miscellaneous stuff. The boat gets used a lot (600hr+ a year) cruising the east coast.
But here are the things that in some cases seem odd, but get used over and over and over:
An eight piece set of stubby ratchet wrenches, open on one end ratchet box on the other. This is what I use for 98% of my wrenching needs. Really, in 18 months I can count the number of times I have broken out my big Craftsman ratchet and wrench set on one hand. And yes, as mentioned the odd metric piece will sneak up on you. A good crescent wrench comes in handy too.
A ratchet screw driver; I nearly cried when I float tested my favorite one. This gets used for 90% of screw driving, basic flat and philips sets cover about 5% and a power driver the other 5. I have a Hatteras, so a also a complete set of Robertson square bits. Various nut driver bits especially for hose clamps.
A large needle-nose pliers with the jaws at a 45 degree angle. Amazing number of uses.
A channel-lock style big oil filter wrench. Many uses beyond filters. One of those rubber strap jobs comes in handy every now and then, though I hate using them.
A screw driver style tack brad puller. In my case because there are so many #rb2rb2@gr5tgr5t%! snaps on board. Used for getting other little things un-wedged too.
Yzer illustrated the essential retrieval, tool, I will add one of those telescoping mirrors as an important companion.
Tripod LED Stanley flash light. I have a couple of different sizes (got a set at Costco).
A good clamp on multimeter. It is worth paying up and getting one that will measure AC an DC amps and voltages, or buying two that cover that. An absolutely essential piece of equipment.
As noted above a good set of strippers and a ratchet crimper, and supply of miscellaneous wire sizes, connectors and terminals, heat shrink tubing plus hose clamps, teflon plumber's tape, small and medium sized pipe wrenches (also many uses). A medium sized pry bar. A small assortment of corks, a rubber mallet and a ball peen hammer, a couple of punches. One straight and one angled metal sharp tipped picks, the size of small screw drivers (oh, add a couple of jeweler's screw drivers too).
A Jabsco hand utility pump and one that fits on your drill too.
If all I had was the above listed, I'd be pretty comfortable setting out to sea. Of course, since I have room for it, there is a pile more, including various power tools.
And spring 20 bucks for an anchor and go check out George van Parys' dissertation on the subject.
George
Hatteras 56 MY
Boston Whaler 130 Sport
Get an 18v cordless drill/driver with attachments for 1/4" and 3/8" sockets to go along with your socket set. You won't believe how handy it comes in and how fast it makes the job go.
I've also reduced the onboard tool boxes to under 75 lbs...but increased the 'spare parts' over 100 lbs.[8)]
90% of my tools are from harbor freight which include Mig and Tig/arc welders, 12 ton press, engine stands, shop cranes and (hydraulic rams for)Boat engine crane as well as a dozen grinders and cordless drills.
You guys will probably laugh, but I too have a plastic tool box. I keep all my assorted tools in it.
In addition, I have a large flat plastic box which contains everything electrical. It is easy to find things since it opens up completely and it is large enough to hold several of those connector sorting boxes. When I have an electrical project, I just grab that box and go to work.
I have a Sears set with 3/8 through 1/2" drive sockets, all the various wrenches metric and SAE, a complete screw driver set. I am getting one of Yzers grabbers. I have a heavy mallet for driving a hull plug if needed. Then I bought the 18volt Sears right angle drill, regular drill, flashlight, charger and a spare 18 voly battery all in one case. Both tool cases take up about as much room as 2 small suitcases. I also have a digital meter, larger cable crimpers up to #4/0 wire and cable shears that will cut up to #4/0 from Greenlee. I have a collection of breakers, small tray of lugs and marine grade crimps and a small butane torch for sealing electrical marine grade electrical crimp fittings. I also have an assorted box of SS screws. I have various coils of spare #4/0 to #8 wire in black & red, some shielded 2 conductor wire and spare sanitation and pump hose. A small case of carbide tipped drill bits and a small case of bits for the drill 1/4" sized stuff. I like having the Greenlee cutters in case I ever need to render assistance to my boat or any I come upon if there is a short that would cause a fire. They have 18" handles and insulated. I also have 3 of every style and sized fuse that is on the boat including the large 350amp style used on the inverter batteries as well as a spare fuse taped on top of the bow thruster. I also have RG-8X and LMR400 cable, adapters, crimpers and connectors but my boat is a floating test bed for WiFi and Cellular based systems and antennas.
Can you believe that there was a time not long ago that people had to hang upside down in their engine compartment with a flashlight clenched between their teeth or wedged underneath their chin. I would put one of these types of head lamps on my list. Get the brightest you can. Some come with a seperate battery pack attached by wire which provide the brightest light.
i have a full size stainless steel tool box top and bottom about 5 foot tall and 4 foot wide 20 inches deep its the best thing i have installed in the engine room so far. the dvd flat screen is second, the most usefull tool is a video scope with a 6mm by 5 foot long probe it helps a huge amount in trouble shooting engines and trannys. i can yank an injector and look in the cylinder in color
Sears 156 piece tool set often goes on sale for ~$90. A complete set of flat tip and Phillips head screw drivers and a volt/ohm meter is what keeps me going for my cruising areas. If I cruised as George does, obviously, my needs would change. Don't forget to outfit the requisite spares while you are at it.
Good luck.
