Windlass or not?
$2500 for a windlass? I never even considered one of those Gold plated models.
My 'windlass' was a $35 electric (probably $150 now) slow, oh so slow, grinder.
I had one on a 24' and a 29' boat. Its too useful to debate about, no matter what size your boat is. Just get it.
I mounted my big one on a Davit that would swing around and could be lashed down forward. That Davit was almost as expensive as the Windlass, but it was so handy for so many things.
Loading heavy stuff up out of the pickup bed and swinging it into the boat, ect! It will keep the Crab pots, Shrimp traps and Anchors from swinging into the side of your boat as well.
Watch your teen-agers swinging on it as your underway in the heavy water. Yelling at kids who do things like that is a waste of breath.
If you want it solely for retrieving the Anchor, mount it on the fore deck, but then its only useful for the Anchor. (remember you can also get that Anchor up with a Float and ring if you have enough room to work)
There's one thing for certain, you will have to be up there where ever the windlass is, to operate it because you have to keep tension on the line your pulling.
My windlass would even pull chain, but it made the whole thing chatter so badly that I never did it again.
"A basic windlass is $1,500."
many windlasses well under $1000... if DIY, you can probably do the whole job incl glassing a locker for under $1000.
I was "the windlass" on a buddy's 35 Carver all summer - I was SO glad when he got the windlass fixed! lol
I wouldn't be able to anchor by myself, so having a windless with the helm control was not an option for me. I have to go forward before I anchor to get things started for my windless is a free falling type. If I had to do it over again, I'd get one that powers down as well as up. Oh well......
I can retrieve without going forward unless conditions require me to cleat off the rode. To me, this is required equipment!
Originally posted by lil red truck
Pascal, I usually am single handling. I was thinking that in the event of trouble in rough water, I'd want to be able to deploy w/o venturing on to the bow.
lrt, I find the windlass takes too much time in case of emergency. Therefore, I keep a smaller anchor with 150 ft of rode on deck in the cockpit. If I need to quickly anchor to avoid getting washed up on rocks, etc, I can deploy that from the stern of the boat, then get the bow anchor down, etc. Something to consider.......
i'm not sure a power down windlass is really better on a smaller boat which will drift faster in a stiff breeze. A free fall windlass will get the anchor down to the bottom much quicker reducing the drift.
when winds are over 25kts, i bypass the capstan on my windlass to get the anchor down and the amount of scope needed out faster.
if your anchor doesn't self launch in free fall, it's not goign to self launch in power down eitehr
I have one on my 26' and wouldn't give it up. I can boat alone or not have to send someone forward. I can secure the rode around a cleat by going up thru the forward hatch. freefall is great for getting the anchor down fast, then back down lock the caspen and set the anchor.
Single handling + surgically reconstructed shoulder = no brainer in my book.
A basic windless is only $1,500 if you shop at worst marine. Many out there for under $1k.
I do not secure my line to the cleat once the anchor is set.
You hear a lot of people complaining about this windlass and that one breaking teeth and clutch parts. My guess is they are having these issues because they either don't have an owner's manual or have one and don't read. My boat has a Maxwell that gets lots of use in fresh water. The manual tells you to avoid damaging the clutch by powering back to deploy rode and then cleat it off prior to setting it. To retreive, you reverse the process and power toward the anchor with the engines while retreiving rode. When you are on top of the anchor bring it up with short bursts of the winch and engines until it is out of the mud. I've been taught to always secure the rode and keep the pressure on the cleat or pin if it's chain vs. putting the stress on the windlass clutch.
No windlass on my boat at 26' and I single hand often. When I've got crew I'll have one at the helm and handle the rest of the anchoring chores myself.
I wouldn't mind having a windlass because I like storm coverage on the gear: in this case 16 lbs. of anchor and about 40 lbs. of chain. That's about the maximum I want to pull up on my own. Because I usually anchor in 15 ft. of water or less, I don't have to haul the full weight all that often. A lightweight anchor at 10 lbs. and maybe 24 lbs. of chain (your boat length) would be easy.
I don't have a chain and rope roller and don't want to modify a classic boat to install one. So, that's where I'm at.
For an able-bodied boater and a boat 26' and under a windlass is a luxury, not a necessity. There are some advantages to anchoring by hand. Anchoring from the bow is more accurate than anchoring from the helm if you need to place that anchor on a small spot. You can haul out your scope more accurately and nothing beats having a hand on the rode for feeling an anchor set or pop loose.
yzer, I don't blame you. That boat of yours is a classic.
All of you ROs, thanks for the input. After some research and discussion with the yard boss and my orthopod, we'll make a decision.
Les, many thanks for this place.
My wife would pull the anchor on our 18ft cc. I took my elderly father in law fishing and when we finished he watched my wife struggling to pull up the anchor and commented" You need a winch on this boat". Without thinking I replied "I already have one wench on board, why would I need another?" Boy did that cost me.
