jim - make sure you use a swiveling shackle to attach the anchor to the chain. otherwise, you'll get lots of knots trying to pass thru the gypsy as the anchor is taken up. as someone else mentioned, tie off the bitter end in the anchor locker. if you don't have a cleat in there, tie a monkey fist (ie a big-a$$ knot) in the bitter end so it can't get past the windlass on the way out. freefall is much nicer than power down, but also much more costly. horizontal is easier to install than vertical and better if you're space challenged in your anchor locker. a primary consideration in any system is the location of the solenoid, as it will have many connections to it. another consideration is where you'll mount the up/down switch and any wiring challenges (ie route to a flybrdge, etc). make all these wiring choices first, then do your calcs for appropriate wire size.
