Windlass project
Terry,
Thanks for the additional picture, I think you just saved me from having an extra hole in my boat.
Originally posted by 32carv
Airbus,
Why would being on an inland lake require all chain and being on the ocean not? I was actually thinking the opposite, more rope less chain to save on some of the weight. My plan was to use 30ft of chain and 200ft of rope. Our inland lake is 60ft at it's deepest and we typically drop the anchor in 15ft to 20ft of water.
Hi Jim,
I didn't say a lake would require it, my point is it just makes things much more easy.
On a lake where I always anchor at a depth of about 15 feet, even with all chain I don't really need that much on board.
If you are a coastal boater, you would probably need to carry much more, so many prefer Rode / Chain combination due to weight and cost.
My boat is tail heavy anyway, so the additional weight up front gets it on plane quicker if needed.
With a Windlass, the connection from Rode to Chain is always an issue, and can damamge the windlass if it get twisted. Not a problem with all chain.
For me, the all chain method solved a lot of problems, but in the end you have to get what works for you and your boating style.
I painted the chain every 20 feet so I know how much to let out.
Good luck
It is a good idea to attach the bitter end of your rode to the inside of the anchor locker "just because". That way, no matter what happens, you will not your entire anchor/chain/rode assembly overboard! I've seen some who just put a monkey's fist at the bitter end of the rode so that it cannot feed through the windlass, but I'd rather have it firmly attached to the boat itself.
I have never tied the end because I always had a vision of one of my "helpers" pulling the anchor and not puting the pin in that holds it. If the anchor dropped I would rather lose it than tear off my pulpit or worse.
I believe your thinking will be different when you are using a windlass.
I have a 27 and 25 foot boat--both have the 700 Lewmar--I would choose the 1000 for your boat (I owned a similar boat in the past). For lake and coastal cruising--35 feet of chain and 200 feet of rode is sufficient---you don't need the weight. When long distance cruising, we had 200 feet of chain, backed with 400 feet of rode--and the size dependant on the size of the boat. That is over kill for your boat.
I have one free fall, which I usually leave locked in power down mode. The other is power up and down. The other advice you have been given is excellent.
The 700 uses 1/2" line and 1/4" High Test Chain, The 1000 uses 9/16" line and 5/16" chain. I have used this weight of line and chain on a Cal 46--about 35,000 lb boat with a 2200 lb windlass and 60 lb anchors, so it may be over kill for the 32 footer.
jim - make sure you use a swiveling shackle to attach the anchor to the chain. otherwise, you'll get lots of knots trying to pass thru the gypsy as the anchor is taken up. as someone else mentioned, tie off the bitter end in the anchor locker. if you don't have a cleat in there, tie a monkey fist (ie a big-a$$ knot) in the bitter end so it can't get past the windlass on the way out. freefall is much nicer than power down, but also much more costly. horizontal is easier to install than vertical and better if you're space challenged in your anchor locker. a primary consideration in any system is the location of the solenoid, as it will have many connections to it. another consideration is where you'll mount the up/down switch and any wiring challenges (ie route to a flybrdge, etc). make all these wiring choices first, then do your calcs for appropriate wire size.
arebilly,
I went to BOC and after joining I apparently don't have the security clearance to see the pictures. Can you post here?
arebilly,
I am having the same problem, 32Carv. Maybe the site somehow knows we don't own Bayliners...
Yah, those Bayliner folks hate Sea Ray owners!!! [just kidding folks]
