Anchors
This has probably been askes a thousand times but how do you anchor? I usually anchor in mud or sand and have a danforth type anchor.
I have worked with anchors a bunch but sorry can't say anything good about danforths. We had a few in the field and did ok if you could tie them to a tree to hold a skiff. There was one at a gravel river we were trying to anchor a fyke net in for catching outmigrating salmon smolt, it weighed over 100# and wouldn't hold in the gravel stream bed. The old style kedge hooks worked ok in tandem there. Anyway I use two folding 24# grapnel like anchors with 24' of chain when the wind is howling(25mph+)set at 90* off the bow.One works fine and tends to set itself in mud if the wind picks up. More scope more better when possible.
I refused to pay to watch "Borat" after it came out. There just seemed to be something mean about the whole idea of the movie. I TIVO'd it last night though from one of the DirecTV channels I already have. So I'm going to watch it about a half an hour from now.
But, I'm an anchoring buff so here goes.
Anchor: Danforth Standard 1300 (16 lbs.) For a storm rating it's two sizes large for my boat, it also has a swivel, a boat length of chain and premium nylon 3-strand anchor line that is well tagged with rode markers.
Where I use it: California Delta with mud bottom. Weeds in the shallows under 10 feet. Plenty of tidal effect, current and wind at times.
Anchoring method: By hand, no rollers or capstan. Wear good deck shoes.
Singlehanded, I go back and forth between the bow and helm as needed. With crew, I handle the anchor and tell the helm what I want to happen with hand signals.
Keep the motor running during anchoring. Notice the depth where you drop the anchor. Don't try to anchor in weeds or grass. A Danforth or any danforth type anchor does not work well in the veggies. Located at the bow, I lower the anchor at a controlled rate. If the boat is drifting, I "lead" the anchor drop so it lands where I want. Once I feel the anchor hit bottom, I let out the rode so it trails out in a line as the boat drifts. I usually have plenty of room to let out scope. I let out a minimum 8 to 1 scope accurately by using rode markers, cleat off the line and carefully keep one hand on the slack line so I can feel the anchor set and the line draw taut.
To set the anchor deeper into the mud, I go to the helm and set the engine into reverse. I'll back up good on the anchor once or twice just to make sure the anchor is set and not dragging. Then I shut down the engine.
I'll keep a close eye on the boat for the next hour, watching the way it swings (lining it up with a landmark helps) and making sure the anchor has not dragged. If I want to shorten scope at that time, then I'll do it.
To raise anchor, I get the boat ready for departure, start the engine and leave it in neutral. I haul in the rode slow enough so that the boat will not travel over and past the anchor. Once the boat is directly over the anchor (rode is going straight down) I'll put about 20 lbs. of pull on the chain and just hold it like that for 20 or 30 seconds. The Danforth will seem to pop out of the mud on it's own with this light pull and a little time. Once the anchor is aweigh I haul it up quickly, splash it several times in the water to break away caked-on mud, and secure the anchor on deck.
If the anchorage gets crowded, I use a smaller danforth type stern anchor to reduce swing.
edit: Borat was way overrated. First 10 minutes had some laughs, the other 80 wasted my time: including some things I wish I hadn't seen. At least I'm not the only person I know who hasn't seen it anymore.
yzer - well put.
in crowded anchorages i just drop to a 5:1 scope.
a couple of important things about anchoring
1. anchors are rarely to big
2. chain is rarely to long
3. scope is rarely to short
my set up - 35# delta quick set, 90 ft of chain, 250' of line
a bit of overkill but considering in anchor overnight at least twice a month...it is peace of mind.
Hey, I haven't seen it yet... plan on being the last one on the planet to do so.
Boatingfinatic,
Where I boat we have the same type of bottom as you and I use a Bruce with 6' of chain and 150' of rope.
blouderback.....you caught my oops....yes i meant scope is rarely to long
that is what happens when i try to sum up a 20minute thought in a few words.
Originally posted by Type-A
Boatingfinatic,
How deep is the water? That set up seems way too short to me.
Or, if you want to get a fisherman's anchor instead of a danforth type:
Boatingfinatic,
Where we boat the water level is any where from 5' to 20'
I anchor in inland water 7-15', usually. 30' of chain and 150' of rope is good for 8 to 1 scope at 22', and 6 to 1 at a depth of 30'. With that much chain I'm pretty confident with 6 to 1.
8:1 !!!
Never would I get the opportunity to put out that much.
" I have worked with anchors a bunch but sorry can't say anything good about danforths."
well, the question isnt' about gravel river bed but sand and mud, in which a danforth is a good anchor especially the alum fortress which has routinely been tested has one of the best holding anchor in sand or mud.
I anchor a lot in mud or sand and I'm always amazed to see how deep my FX55 digs... whenever it's time to go the following morning, i often need to use a little power or wait a few minutes to break it loose. it's held me in 30 to 40kts gusting 50+ while others with plow types where scrambling to start their engines in the midle of the night.
that said, there are two limitations to a danforth styled anchor : they will not set in grass and sometimes they may not reset on a large wind shift (180 deg) if they got clogged with muds or weeds.
another issue with a broad statement about danforth is that not all danforth are created equal... some of the cheap danforth knock offs are far inferior to the real thing or Fortress.
Yzer's post is right on...
when picking an anchor, dont' settle for the "Recommended" size found in most catalogs, go one, possibly two size above and use as much chain as possible.
in the typical 10' water we have around here and a crowded anchorage, I usually use 75' of chain and my FX55 has almost never failed to set on the first attempt. In higher wind and open bay waters, I may need to use a little more scope (100 to 125 in 10', which with bow height amounts to 7:1 scope).
In all fairness, I think your skills are more important than the anchor type... every week end I see many guys unable to anchor, I bet they blame their anchor not their 3:1 almost no chain scope deployed while reversing too fast...
Pascal, you'll be a good one to give me input on this. I'm getting ready to haul the boat down your way for a multiple week trip to the Bahamas next Spring. Thus, I've got an excuse to buy new toys! First chore, upgrading the anchors. Here's what I have for my 30' power cat with 10' beam and about 5,000lbs loaded:
13# West Marine steel fluke
75' chain, 200 feet nylon (primary/windlass)
20' chain, 200 feet nylon (secondary)
POS off-the-shelf "claims to be rated for 30' boat" aluminum spare used as a stern anchor (4' chain, 50' nylon)
We anchor most weekend off the Chesapeake. Never had a problem. I set anchor with about a 5:1 scope, then I usually (when able) go to 10:1. This was mainly before I went from 15' of chain to 75', so I might be able to slack that off a touch if things get crowded.
With all that said, I'm looking at Fortress. The FX-11 (7lbs) is rated for my size vessel. My natural tendency was to go for the FX-16 at 10lbs. However, that doesn't want to fit very well on my rollers.
My question to you: Since I'm on the light side of things boat-wise when it comes to a 7" Fortress rated for up to a 32' boat, might I feel safe getting away with the FX-11 should we get stuck in a blow? I'm thinking not. Perhaps get the 10lbs FX-16 as my secondary (thus, put it out when needed) and go ahead with the FX-11 (7lbs) for use "everyday" with my rollers and windlass? Or, if things get bad, would having two FX-11's out suffice?
I'd call that a "plow". I've heard "Danforth" used for both plow and fluke (I think the real Danforth makes both designs?). I'm not sure which is correct considering it's like calling a "Tissue" a "Kleenex".
Kurt
a cat present more surface to the wind than a monohull so i really woudln't trust the "recommended" size... personally, i'd go for an FX23 on your boat even if that means upgrading the roller (the windlass shoudl be fine)
i dont' get the concept of lunch hooks or using a smaller anchor in normal conditions and then relying on a bigger back up. once you're anchored and that thunderstorm moves in, you dont' want to have to deploy another anchor... at least i dont... all i want to do is maybe add another 25' of rode and know that I'm secure.
get the FX23 and use your 75' chain rode on it... that's all you'll need.
i'm kinda lazy when it comes to anchoring... i want to drop the hook and rode and know that I'll get a good night sleep ! Even though i know that many guys get away with a undersized hook and minimum chain but when the wind picks up, they end up scrambling around... no thanks ! :-)
Danforth does not make a fluke claw or plow anchor under the Danforth trade name. The original Danforth company was sold many years ago. It was owned by Rule for a while and has been owned by Tie Down Engineering for some years now.
The Danforth Standard is the original design. Now there are there are the Danforth High Tensile and Deepset II designs, each with i's own characteristics. Under current ownership, the original Danforth designs and quality remain very high and are American-made in Atlanta, Georgia.
The Fortress Anchor uses the basic Danforth design, but offers lighter weight, no-rust aluminum constuction and a fluke angle that can improve holding in soft mud.
There are also many knock-off anchors that mimic the Danforth design.
I agree with Pascal about the lunch hook concept. It's especially important to have the right anchor in use on a smaller boat where there may not be room to store a second "storm anchor."
Danforth offers more size choices than most anchor manufacturers. That's one reason why my anchor is two sizes larger than Danforth's 20 knot choice for a 26' boat.
http://www.danforthanchors.com/index.html
I still like the Danforth Standard: heaviest for it's size, takes a beating and well-priced.
